Spare Parts Numbers for Yanmar 3YM30
harley
I have a 2009 Yanmar 3Ym30 and wondering if someone has a good parts list with product numbers. I am having difficulty
finding a good list to keep on hand. I do not have a 3YM30AE and often see parts for that motor and wondering if they are the same. It seems that Yanmar changed the part numbers and hoping the replacement numbers are ok with the older engines.
I am looking for:
Oil Filter
Racor Fuel Filter Cartridge
Raw Water Impeller (Maybe this is a Jabsco Part?)
Thermostat
Harley
Harley,
Oil filter Mann - W67/1 , WIX-51365
Raco filter R11T-0705
Raw water impeller 09-810B-1 F4 series
Thermostat #128990-49800
Fuel filter #104500-55710. WIX -33262
Air filter Yanmar 128270-12540
Wiper blades #31112B
Yanmar key #123482-91291
You can down load yanmar parts catalog # OCR10-656000
Hope this helps! Bob
bob daily":14l23gbe said:
Harley,
Bob,
Thank you much for that. Think these are all good for a 2009 motor?
Harley
Harley, my tug is a 2009, so I would expect us to have the same engine. Most filters can be purchased at the local auto store, the rest can be ordered via Amazon or any marine supply. Ranger Tug parts department has a order sheet with all the numbers and I'm sure they will forward you one if requested.
Little things that break or you lose like the wingnuts for the mast and such can be ordered from the supplier or others with a little research. Hope this helps Bob
The fuel filter listed here (Yanmar part) is too long for my 2009 Yanmar 3YM30. It is Yanmar 104500-5570. The boat came with a couple filters that do fit and are a bit shorter than the Yanmar. The one I am using that fits his a ITACO 104500-55710 which is the same part number as the Yanmar….but it fits. This is the engine filter, not the first stage Racor water separator filter.
Also on the filter box is TS105 and For 3HM Diesel.
Same diameter and structure as the Yanmar…just shorter. I am pushing the open end over the nipple inside the filter house in. When I try the Yanmar part……the filter housing does not fit (filter too long).
Any idea what the real Yanmar number is?
Harley
Harley, if you look on Amazon for the WIX fuel filter #33262 you will notice two with the same number , but one is longer! The best thing to do is take your old filter to the auto parts store and match size prior to purchase. Not sure if the yanmar number has the same problem. Bob
