I just thought I would share a cheap upgrade I performed to the stock Fusion 700i on our C26. The stock fusion speakers just plain suck and are not a great match for such a small amplifier in the 700. I sought out much more efficient speakers all around. In the cockpit, I simply upgraded the 4" fusion speakers with the marine 4" Kicker speakers, efficiency of 89 db and 2ohm, which the fusion amp is rated to handle within specs. For the pilothouse, I purchased a set of four Polk Audio TL1 Satellite speakers. These are also rated at 89 db efficiency, yet at 8ohms. So I wired the four pilothouse speakers to the second zone on the 700, which nets the 700 seeing 4ohms, well stated within it's specs. So two Polk speakers where the old fusion pilothouse speakers were mounted, and I added two more in the forward berth, all sharing zone 2.
Kicker Cockpit Speakers:
https://www.amazon.com/Kicker-Coaxial-S ... 302&sr=8-1
Polk Audio:
I bought some second hand on craigslist. 4 for $80. These speakers have been around a while so they are out there on the used market. If you want new:
https://www.amazon.com/Polk-Audio-TL-Sa ... 720&sr=8-3
If you are picky about sound quality, the upgrade was dramatic. Hope this helps someone, as I have already received a plethora of help and advice from others.
Severum
Polk Audio:
Severum
