sheral
- Mar 23, 2015
- C-24 C SE
- FMLT2114H415
- Sheral Ann (2015 R-21EC)
Re: 2015 Volvo Penta D1-30F
On two occasions now the Volvo Penta in our 2015 R21-EC didn't start. The other day, right after our initial service check up we went to start the boat and it didn't turn over. Again today while out fishing it failed to start.
Typical start procedure: We turn the off/on button on and watch the tach lights come on then push the start button ...
The first time the engine wouldn't start we had tried the a/n procedure about three times and then checked the engine compartment. On the first occasion, along with going through the usual start up procedure (and ensuring the throttle lever was in neutral) I wiggled the engine battery cable to the hot terminal and the next attempt it started. So when I got home I tightened up all the battery terminals and it worked fine until today.
Today we were out fishing and had turned the engine off when hooking into a fish. When the high fives were finished, the engine didn't engage when I hit the start button.
Checked all the battery leads again and moved the throttle control forwards and backwards and into neutral and it started.
The only thing done both times was to move the control - throttle lever forward and backwards and into neutral to ensure it was in neutral and wiggling the battery cables. However today the last thing I did before the engine started was move the throttle control and made sure it was still in neutral.
Is there some type of 'lock out' that doesn't allow the starter to turn if the control isn't in neutral or if the control lever doesn't think it's in neutral?
Any ideas?
Thanks.
Any ideas?
Thanks.
