Steering Wheel Hydraulic Oil
pdo
C-288 C
Selah
Came back to my 2021 R23 and discovered that hydraulic oil had been leaking. Any ideas of the cause or cure? Thanks
Check the cap on the steering wheel to make sure it’s tight. Where do you see the oil?
I notice oil on the floor near he helm. Looked like it was coming from the cap area as far as I could tell. I checked the tightness of the cap and it seemed quite tight. There’s also bit of play in the steering wheel, built i can’t remember if that is the way I was before I noticed the leaking oil.
The black cap is vented. If you look carefully you will see that at the top is a loose vinyl cover. If the pump is overfilled some oil will escape. This not uncommon.
Note , if there are dual helms only the higher pump has a vented plug. The lower plug will be grey and not vented.
