Sweet_Pea
- May 24, 2012
- R-27 (Outboard)
- Non-Fluid Motion Model
- R25 SC (sold)
- Sweet Pea (2024)
Thought we’d share some storage and organizing ideas that help us maximize space and add creature comfort, with links to items that work on our R27-OB, if you’re interested. Many of these ideas could work on other models as well.
Feel free to post other ideas and solutions you've found.
**NOTE: Links provided for info...you might find better prices elsewhere.**
SAFETY EQUIPMENT
We mounted fire extinguishers in the v-berth, at the helm and in the cockpit. These locations keep the extinguishers accessible yet out of the way.
The throwable ring is light enough that we could mount it under the center lazarette lid.
PHOTOS
Fire extinguisher locations
https://www.dropbox.com/scl/fi/br3l...ey=fo73w4e8gfndysbb7jpp43or7&st=uhv6xhnd&dl=0
Throwable ring
https://www.dropbox.com/scl/fi/k9ds...ey=vk4vdcfcmzhdlqnvveh9qwhby&st=ou49o65h&dl=0
STERN REEL
Our boat came from the factory with an engine mount that we don’t use since we store a Torqueedo in the center lazaretto. We repurposed it as a mounting place for our stern reel.
Stern reel
https://www.dropbox.com/scl/fi/cw4c...ey=xzxhrjwqlwdd40lomc8oes7oq&st=cwesw5i5&dl=0
WINDSHIELD PRIVACY CURTAINS
Screen out sun glare and heat inside the cabin while adding privacy. A single, 8-foot Recmar curtain track fits perfectly and comes in a kit with almost all required parts. No cutting needed. You’ll need bend the track at each end by the windows and bend away sufficiently around the wood covers behind the windshield wipers to enable the curtain to slide freely. Before mounting the end brackets, we slid the curtain on the track to ensure it didn’t get hung up around the curves.
The most difficult install issue is reach. We used our cooler on the v-berth step and in the helm area as a stepstool. Also, make sure to stuff towels along the windshield to prevent screws from dropping in the crevasse. (Lesson learned!)
The curtain fabric should be light-weight. We lined ours for privacy. Shackles are placed every 6 inches. We needed extra shackles, as 16 was not quite enough. Also, in the design detail photos, you’ll see that simply suspending a curtain exposes the track and leaves a visual gap between the top of the track and the ceiling. We installed a decorative topper to address these issues and tacked it to the curtain to keep it upright. We used exterior strength velcro to affix the tiebacks to the window sill. Alternatively, snaps on the wall would work as well.
PHOTOS
Installed curtain track
https://www.dropbox.com/scl/fi/pb6h...ey=zkcjjqpbg84f0g3kdc4qhpaif&st=fu9kvclw&dl=0
Curtain at night
https://www.dropbox.com/scl/fi/jz34...ey=67mctegxvtrygehl1a9bslr38&st=u7dia4hk&dl=0
Curtain design detail (before topper was installed)
https://www.dropbox.com/scl/fi/8mpr...ey=kt357ou6jt0oz2wi2sc8g8dym&st=5c1tfb8q&dl=0
Velcro tie backs and center join
https://www.dropbox.com/scl/fi/i2xn...ey=itl7ynmsln24acvkn2jtu4pv0&st=3zj8hxtj&dl=0
Towel in the gap to catch screws
https://www.dropbox.com/scl/fi/kzff...ey=asw86n0byjknust2hafetgdry&st=5ner4ywa&dl=0
PARTS LIST
4396 RECMAR Deluxe Shower Curtain Kit - Flexible - 8 Feet includes:
https://www.curtain-tracks.com/recmar-4396-deluxe-shower-curtain-kit-flexible.html
----8 foot Track (1)
----Ceiling Brackets (8) - SKU 4126
----End Stops (2) - SKU 4134
----Wheel Carriers w/ Shackle and set screws (16) - SKU 103967
103967 RECMAR I Beam Nylon Wheel Carrier With Shackle (pack of 10) SKU
https://www.sailrite.com/RECMAR-4121-I-Beam-Nylon-Wheel-Carrier-with-Shackle
Fire-retardant polyester faux dupioni silk in Gold (2 yards, 120 in wide)
https://mytextilefabric.com/products/ifr-faux-dupioni-silk-120-wide
PHYFERTEX COCKPIT SUN SCREEN ENCLOSURE
Clay at Churchill Brothers Upholstery in Anacortes created a sun shade for our cockpit (Note: lead time of 6 months). The Phyfertex allows us to see out while still blocking sun. Each side has two, roll-up, zippered sections and the back has three sections. Clay created a pass-through for the dinghy line with brass turn buckles. When fully deployed, the Phyfertex cuts down wind and helps repel some rain. Cockpit is damp, but not soaked in the rain. In hot weather, sides opposite the sun will need to be rolled up for ventilation.
PHOTOS
Starboard side Enclosure
https://www.dropbox.com/scl/fi/pfbz...ey=wovjfo7zpnd4ytwvl831yygk3&st=39gindup&dl=0
Port side Enclosure
https://www.dropbox.com/scl/fi/qpl8...ey=yp4oydu9cxp6p5k5toksiif8c&st=7xzwre5h&dl=0
Dinghy line pass-through detail
https://www.dropbox.com/scl/fi/uvus...ey=b5m4xnyihhpo9zdh0ajte0qjz&st=el16vxyb&dl=0
TEXTILES
Phyfertex (color: Burlap)
https://www.sailrite.com/Phifertex-Plus-Mesh-Burlap
Bias tape edge in Sunbrella Toast, to match bimini
https://www.sailrite.com/Binding-Acrylic-Toast-1
COCKPIT COAMING BOLSTER COVERS
To keep the upholstery clean, we covered the coaming bolsters with matching canvas. Secured to the back side with Velcro.
Port and Starboard bolsters
https://www.dropbox.com/scl/fi/cymy...ey=znjp5jbfdcrukabq7tr4heswr&st=eu96t4or&dl=0
FABRIC
Sunbrella Marine Grade 6028-0000 Toast 60" Fabric
https://www.sailrite.com/Sunbrella-6028-0000-Toast-60
INTERIOR WINDOW & CEILING HATCH COVERINGS
We used fire-retardant, marine-grade vinyl to make interior coverings for the stern windows, door and window over the galley. The 3/8” adhesive Velcro on the window frames is discreet. Velcro is sewn onto the vinyl coverings for strength.
All the coverings roll up and store in a single, adjustable length drafting tube that we hung under the aft galley seat. (To prevent the Veclro strap ends from pulling monkey fur, we Velcro’d a 16x24” piece of vinyl on the wall behind the tubes.) We added a second tube to store a canvas screen door covering that we velcro to the inside door frame. The screen was made for our R25-SC and fits the R27-OB.
To cut glare and heat from the ceiling hatch windows, we cut a piece of vinyl to lay on top of the screen when the hatch is closed. When open, we remove the vinyl and store it.
PHOTOS
Vinyl window coverings - will post soon
Canvas door screen - will post soon
Vinyl ceiling hatch shade
https://www.dropbox.com/scl/fi/uhq8...ey=fnw2n0c95cjd1mm307z4nqu4s&st=q6gdr478&dl=0
Storage tube (4.88"L x 4.88"W x 30.25”H)
https://www.dropbox.com/scl/fi/tts7...ey=ymwrr4g8rj3tlkhgfwydvgqad&st=fwq59mm3&dl=0
MATERIALS
Storage Tube
https://www.amazon.com/gp/product/B013PAXM74/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
UV & Fire resistant, marine grade vinyl (4 yards, 54” wide). Color used is cream:
https://www.amazon.com/gp/product/B079HH52ZB/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
BINOCULAR & HEADSET RACKS
A second teak binocular rack is perfect to hold our headsets, keeping both items handy at the helm. NOTE: there are two sizes for the rack. We ordered the small 4-7/8"x3-1/2"x8-3/4". Inside dimensions: 7-7/8”L x 4-3/8”H x 2-7/8”D.
Teak binocular rack
https://www.dropbox.com/scl/fi/xfb5...ey=hd8m2bkcoshlhg6l4at26efnt&st=s2f9n9u1&dl=0
ITEM
SeaTeak 62702 Binocular Rack
https://www.amazon.com/gp/product/B00429YGKU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
HELM FAN
A marine mechanic wired a fan to the unused accessory switch on the helm dashboard. This helps with interior ventilation and swivels to help clear fog on the windshield when needed.
Helm fan
https://www.dropbox.com/scl/fi/dy79...ey=75azfdyq3lhdhud7b2d665tsy&st=yk8js8fs&dl=0
ITEM
Caframo Ultimate 757 12V 2-Speed 7 inch Fan - Direct Wire Black
https://www.amazon.com/gp/product/B00NYTN6LE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
GALLEY ORGANIZATION
It took a while to figure out, but we’ve maximized space in the galley. Bins make it easy to pull items out with a gap left along the side for slipping narrow items. Stacking glasses help fit more behind the fiddle.
For extra counter space, we removed and stored the stainless steel pot holders and slipped a teak cutting board on top of the stove. The heat-resistant, gray silicone bar mat on the counter contains drips from drying dishes and serves a dual purpose as a resting place for hot pots and pans.
Dishes, bowls, pots, tongs and hot mitts stack inside the oven drawer. We store baking pans, pot lids and extra items in the oven.
We used one-wrap Velcro to hang the microfiber chenille finger towel near the faucet. To keep the hand towel in place on the oven door, we use a magnetic clip. The magnet is very strong.
For trash, we installed a trash can designed for the back of a car seat at the base of the table. There was more foot area on our R25-SC than on the R27-OB, but it works.
PHOTOS
Hand towel made with love by Nita reminds us of Margarita Bob and stays secure with a magnetic clip.
https://www.dropbox.com/scl/fi/3d0w...ey=0zl89amsjyvq9pfnqiyljmjwr&st=h9fszsgr&dl=0
Stacking glasses (photo on left)
https://www.dropbox.com/scl/fi/zo49...ey=1xww9smjibditewpkglg2mha1&st=he2pgr9m&dl=0
Standard bottles instead of retail liquor bottles maximize space; Acrylic bins in two sizes. (3 standard wine bottles fit in a tall bin, not shown to left of liquor) (photo on right)
https://www.dropbox.com/scl/fi/zo49...ey=1xww9smjibditewpkglg2mha1&st=wx02hib1&dl=0
Silverware drawer organizer
https://www.dropbox.com/scl/fi/nu3r...ey=kmqpogwmnygh96z3nxz6n4c66&st=jbjf0str&dl=0
Adjustable drawer organizer (not pictured, link to item is below)
Galley trash can
https://www.dropbox.com/scl/fi/d08w...ey=wjtl12a439a3r7q5n3kfwcklw&st=jt0qi5ev&dl=0
Cookware & serveware storage
https://www.dropbox.com/scl/fi/5962...ey=pvkv31808j4no63b5cv86xq25&st=tha4xs2h&dl=0
Teak cutting board - photo to come
ITEMS
Stackable bins - tall (10" x 4" x 5”)
https://www.amazon.com/gp/product/B0BSVSYPRT/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Stackable bins - short (16" x 4" x 3”) for liquor. Liquor bottles: we repurposed Sailor Jerry plastic rum bottles (375ml) that fit the bin width perfectly.
https://www.amazon.com/gp/product/B00UVCDFCW/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
Silicone bar mat (gray or black, 12” L x 18” W)
https://www.amazon.com/gp/product/B09VCX39F5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Teak cutting board (16.5''L x 13''W x 1.5”Thick) - need a table saw to cut the length down by 1/4” inch to fit
https://www.amazon.com/gp/product/B0BFRGHX4H/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Silverware drawer organizer (14"D x 10"W x 2.5"H)
https://www.amazon.com/gp/product/B0CBTMHFWW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Drawer organizer with adjustable dividers
https://www.amazon.com/gp/product/B01ALKEFDQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Magnetic towel clip
https://www.amazon.com/gp/product/B0CMQFRKLB/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
CHART STORAGE, TV & SOUND BAR, MISCELLANEOUS STORAGE
Cruise guides and folded charts fit in a teak chart rack at the first mate’s seat. Oversize charts slip along the side of a matching teak storage bin inside the hanging locker. The bin is convenient for miscellaneous items. We use clips to pin up long garments to clothes hangars.
Acrylic drawers organize small items. They are meant to stack, so the lip on the top prevents items from sliding off. The tall OXO storage containers are handy for coffee pods and other small items.
The green zippered organizer shown in hanging locker photo is a cable organizer for phone, headset and other charging cords.
The sound bar has an audio cord that plugs into the TV. We had to order a longer cord to enable the TV to pull away from the wall. We stream using ROKU, which plugs into the TV via an HDMI port.
PHOTOS
Teak chart rack and Teak bin in hanging locker
https://www.dropbox.com/scl/fi/hkgc...ey=qcjxfdy5wtk1o2nct0ms67hqo&st=5x0bz3ew&dl=0
Hanging locker view with TV, soundbar and organizing bins and drawers
https://www.dropbox.com/scl/fi/72of...ey=yhuhyhqjoof8incke6ivenkwq&st=avpw07gg&dl=0
ITEMS PICTURED
Whitecap 62502 Teak chart rack (29.972 cm L x 27.94 cm W x 10.921 cm H)
https://www.amazon.com/gp/product/B00MYTNKOI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Teak bin (16"L x 13"W x 7"H)
https://www.amazon.com/gp/product/B07MBPYVV8/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Acrylic 2-drawer box (6.5" x 7" x 5”)
https://www.amazon.com/gp/product/B00J5L12K2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Acrylic 3-drawer box (6.5" x 7" x 5")
https://www.amazon.com/gp/product/B00J5L1626/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Car garbage can (10.5"L x 7"W x 12.5"H)
https://www.amazon.com/gp/product/B016AOLKOE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Sound bar
https://www.amazon.com/gp/product/B09ZQCJHVL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
HEAD
To avoid clogs, we don’t flush paper in our head, so it’s convenient to have a trash can near by. We purchased this car trash can some years ago and it’s no longer sold, but posted a link to a similar one below.
To mount it to the lav wall, we had to McGyevor a bit. We found that a door jamb strike plate works great to hang it from clips in the back of the trash can. You do want to make sure to hang it as close to the counter as possible, which can act as a stop and prevent the trash can from slipping off the strike plates, but still leave room to install, if that make sense?
A microfiber chenille finger towel dries quickly and kinda looks like a sea urchins suspended from the towel bar with one-wrap Velcro.
PHOTOS
https://www.dropbox.com/scl/fi/22fq...ey=9sjmy36bqt6265f8kovujerbt&st=e601pk20&dl=0
Head trash can
https://www.dropbox.com/scl/fi/lxnf...ey=we82i62gbe6al5jhu6tu41nuc&st=tjogvpjj&dl=0
ITEMS
Car trash can for head (10.8 in L x 6.7 in D x 11.6 in H)
https://www.amazon.com/gp/product/B0BG2WMG5D/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Door jamb strike plate - 2 needed (example here…verify the size you need for your particular trash can.)
https://www.lowes.com/pd/Tell-Manufacturing-1-1-4-in-W-x-L-Stainless-Steel-Jamb/1000001056
TABLE BED DEPLOYED
We couldn’t find a photo when we purchased our boat. For new owners wondering what the table bed looks like, here’s a pic.
Table Bed
https://www.dropbox.com/scl/fi/midv...ey=wtn7v4ii24silifd6vz44ozkl&st=fp782a8l&dl=0
SAFETY EQUIPMENT
PHOTOS
Throwable ring
STERN REEL
Stern reel
PHOTOS
Curtain at night
PARTS LIST
PHOTOS
Port side Enclosure
TEXTILES
FABRIC
PHOTOS
MATERIALS
Storage Tube
Teak binocular rack
ITEM
HELM FAN
Helm fan
ITEM
GALLEY ORGANIZATION
PHOTOS
Galley trash can
ITEMS
Magnetic towel clip
PHOTOS
ITEMS PICTURED
Sound bar
HEAD
PHOTOS
Head trash can
ITEMS
TABLE BED DEPLOYED
Table Bed
