Strange Set Of Keys Found
fishheadbarandgrill
R-29 Classic
Sunfish; Vespa GTS 300 Super
Sea Shanty
Check if they fit the sliding door.
Yep, that's the sliding door key.
Thanks! That's it. Didn't even think the sliding door had a key.
I need one for my door, is there a three digit code on it?
I’ve had my R31cb for a year got the same key, had no idea what it was for before now.
Yes, there is a code. There appears to be 40 different codes you can use. 201-240. Suggest you contact RT and find out which code was used for your hull number.
Check the lock face, front and back. There might be the corresponding code stamped in there.
You should keep that key near your sliding door. When you open your sliding door it stops with about 4 inches of door still covering the whole opening. If you hold down the latch again and give it another push open you can get it to open completely. The problem though, at least on my R29, is that I had to use the key to get the door to close again. Maybe I couldn't operate the latch properly! I liked the extra width when having to get in and out of the boat quickly for handling Lock lines. A bigger door would be nice but then again if I lost some weight the door I have would be fine.
Cheers, Leon
