Structural Hull cracks on both sides of OB engine
Cotemar1
S-250 C
FML25C01B324
M&M
I have a 2024 Solara S-250 Coupe. We have a structural issue with hull cracks on both sides of OB engine. I had the STB side fixed once, but it came back after 8 months and now the ports side is getting bad also. I am looking for a solution, so I do not have to get this repaired every year.
I have had this repaired once , although in your case it looks as if the substrate may have structural failure ,
Movement looking at the jagged edge there is stress from the structural supporting material's A marine surveyor licensed could confirm and dig deeper for a permanent solution.
Mine was superficial so far! , But I check it after every trip!
