abcandjrc
- Oct 10, 2010
- C-24 C SE
- FMLT2160D707
- Little Lady (2007)
I have previous experience with stuffing boxes of the type on our R21-EC. But access to the stuffing box on it is really bad (although I see from the forum that on the R-21 "classic" it is even worse with batteries mounted above it). It appears that if about an extra inch of hose had been used, exposure to the wrenches would have been improved immeasurably. In addition, ours appears to have been installed by two apes using pipes on the wrenches to lock it up.
What I have is a couple questions and what I need is some suggestions from those who may have conquered theirs. I have tried everything I knew to try and am still stumped. Right now it is soaked with PB Blaster until I can try again. I hope someone will tell me some magic way to get the adjustment components unlocked.
1. On others I have worked, the lock nut and the packing nut were both threaded on the same housing. On this one it appears that what I think would be the lock nut (the thin, aft one) is threaded onto the housing but the packing nut is threaded onto it. Is that correct?
2. Are the all the threads conventional right-hand threads? They appear to be when I stare at them but they defy all my attempts to move anything.
3. Which of the two nuts is the actual lock nut? I would guess at the thin, aft one, but all attempts to move it have been futile.
5. In what sequence did you "crack" the lock apart? Hold the thin, aft one and turn the forward nut, or the opposite?
6. If all else fails, it appears that if I take off the hose clamps the unit should slide forward over the shaft. That would possibly let me get a couple pipe wrenches on the two nuts. Does that make sense? Is it do-able?
Thanks for any suggestions, particularly from those who have actually done the job on an R-21.
