I have not replaced the packing yet but have measured the clearance between the coupling and end of packing gland. It is tight but doable. A flexible T handle packing puller is needed to remove the packing and a L-shaped tool is needed to install the packing in the gland. ( I have a wide blade screwdriver that I bent at a 90 degree angle. I used this in tight packing gland installations in the past). dclagett is right on about the hose length. If it is longer then needed that can be the difference in having enough clearance. If your boat is out of the water Pull the prop, uncouple the coupling, Pull the coolant line off the packing gland, mix up some soapy water solution squirt in the fitting to lubricate the shaft cutlass bearing and the shaft will pull out easily. Remove hose and gland has an assembly, measure and adjust hose length if necessary, repack gland on the bench, Reinstall in reverse order. There are some installations that this is the method that is needed because of tight clearances.
