Joan and Jim
- May 2, 2015
- C-302 C
- FMLT3119B717
- Non-Fluid Motion Model
- Dinghy "Tiny Bubbles"
- Bubbles
To say that my understanding of electricity is limited would be an understatement so I seek advice. Last year my house batteries quit. The electrician replaced them with four Interstate SRM 27 deep cycle batteries which I believe are classified as "flooded". The battery monitor which I had installed seemed to indicate that the solar panels have been charging the batteries ever since. I have detected no problems. However, I recently noticed in the Operation Manual for the SS Duo that there are 5 switches on it, the first two of which are called "Battery Type Select" switches. The switch for "flooded" batteries is supposed to be in the "on" position which did not occur when the new batteries were installed or since. I intend to remedy that but have the following questions:
1. I assume that switch #1 is to the house batteries and #2 to the engine. Is that correct?;
2. Since there are separate switches for the house and engine batteries, I assume that there is no problem with having flooded batteries for the house battery bank and a separate type for the engine. Is that correct?;
3. I do not know why the different positions are required. What might have been the effect on both battery charging and possible damage to the batteries for my not having the switch on?
Thanks in advance.
Thanks in advance.
