Swim PLatform Design Loading
LADYBUG TOO
C-288 C
FMLT2916B909
LADYBUG, TOO
What is the design loading for the R-29 Swim Platform. We have had four adults on the platform and it seems to be capable of a much heavier load. To be on the safe side it would be appreciated if the design load could be provided.
Pat
Ladybug, Too
Great question
Hello Pat,
We actually don't post a load on the platform. I would say keep it to 3 adults or less. I can tell you I've had many more at a boat show but not recommended.
Good questions.
Andrew,
Thanks for the info. I am a retired civil engineer and I would not post a specific load either. When a bridge falls the civil engineer goes to jail, when an airplane crashes, it is pilot error. I did some rudimentary analysis and I am impressed with the numbers which, of course, I won't share. It ultimately comes down to the shear strength of some of the fasteners as I think the compressive strength of the struts is greater than the shear strength of the fasteners. It is a good design but ought not be abused with excessive loading. Two is company, three is a crowd and the heck with four on there at one time.
Pat
Ladybug, Too
Here is a little something to watch for on your swim platform especially if you live in the water all the time:
As a semi-annual inspection, I check the platform support bracket bolts.
After my first two years in the water I found that electrolysis had significantly weakened three of the four lower bolts that are below the waterline.
I have since added a zinc to each support.
Good to know about the electrolysis issue. I'll get some small zincs like the kind that go on prop shafts and use them.
