Teak/holly floor has come loose
Mikep
R-31 S
Dive In
A section of the floor in my v berth has come loose and I need to reglue. Can I get some insight as to what glue is used at factory and what others have used to fix loose sections.
I have photos in my album of replacing the floor material in the V berth area. I used a heat gun to help soften the glue to remove the wood from the fiberglass sole. Once the wood is removed I used a solvent to remove all the old glue so that a good contact surface would be available. Cleaning and prep is important to a good adhesions. I used https://www.google.com/aclk?sa=l&ai=DCh ... pgU&adurl= To glue the floor down. This is what Fluid Motion advised to use. Use a good filter mask when doing this. If not you will be has high as a kite!!!!
