This could happen to anyone with an inboard engine
Does it fire at all? Have you changed the filters? Is there a priming pump on your engine? Which engine do you have?
It does not fire. I have not checked the filters, but I will.
It is a yanmar 4BY2-150/150Z.
Where/What is a priming pump?
I am thinking that it primes the injectors,
I appreciate your help
is there risk adding biobor to a tank that hasn't been filtered in a while? will it congeal and cause a blockage?
It's just poison. All it does is kill the bacteria. Dead or alive it plugs filters.
Checking/changing the filters is the place to start. Might have to change both if you have primary and secondary. One likely mounted somewhere in the engine space and second one mounted on the engine itself. The early boats weren't all built the same and someone might have changed it so can't really say where to look for them. If you change filters and the engine starts you've pretty well zeroed on on the problem. But it is pretty odd if the engine was running OK, you shut it down, and now it won't start. Typically if filter is plugged it should have shut down or at least slowed the engine down last time it ran.
Typically the priming pump is on the same housing as the engine mounted filter. If you search on line you can probably find a manual for the engine. Or maybe someone with the same engine will chime in here...
When I replace the filters, do I need to bleed the fuel system?
If so, how do I do that?
Another thought, could the fuel fill pipe be clogged with growth?
If so, how would I clear that?
Can't answer whether you HAVE to bleed the system. It's always a good idea but different engines, filters, etc, are different. On my Cummins/Mercruiser there is a bleed port on top of the engine mounted filter housing and a priming pump. But I'm able to get by without bleeding it as long as I fill the replacement filter with fuel when I install it. The pickup tube being plugged is a thought. There have been reports by some owners that they had trouble with a plastic screen on the pickup getting plugged. If I recall Ranger stopped putting them in but can't recall when. Likely later than 2010. The pickup tube can't be gotten at without cutting an access port in the deck inside the cabin. The pickup is just forward of the cabin door step.
Do the easy stuff first. Filters...
Also does your primary filter have a clear bowl on bottom? And/or a drain? Before pulling it you should drain it and see how much water you get. Biological growth only occurs if there's water in the fuel. If/when you clean up the fuel(aka polish it) the filters should knock out the water.
Thanks Dan, so much for your suggestions and insights. I do have an inspection port cut into the cabin floor. I can see the fuel hose pickup. However, I will do as you suggested by doing the easy things first, check the filters. The primary filter does have a clear bowl. I will drain it and check for water. Blessings. Rob
Sounds good,
Now, if I could just get the engine to start, it does crank.
Any suggestions on how to get it to get it to start?
You didn't say what engine,,,, But on my 2011 RT 27 with 4 Cyl Yanmar I had a crank no fire situation and found that the Lift pump relay and holder were burned. Take the cover off the ECM (dont drop the allen wrench into the bilge) and inspect the relay and fuse for the lift pump. And when you changed filters did you fill then with fuel?
Good Luck:
Bill
The first thing is to unhook the fuel line right at the engine. Get a 5 gallon (or such) can of fuel to set in the cockpit (or dock) and enough hose / fittings to hook up to the engine. Use an electric fuel pump to blow fuel through and eliminate air bubbles at the engine fitting so that the line is primed.
Get the engine running (and generator) to prove that the fuel injectors are not clogged with crud. Do whatever the mechanic has to do to get them running properly.
The next thing is to address that the fuel lines / Racor are clear of crud, clean and flowing properly from their unhooked fend at the tank all the way to the engine. .Transfer the end of the portable fuel supply to the tank end of the fuel system (unhooked from the tank of course) Reinstall the fuel line to the engine and prove the engine will run on the portable fuel supply passing from the tank end to the engine end.
The final step is to open the fuel tank. Pump out and clean it spotless (nasty job) Hook the normal fuel line and strainer back up. Refill with fresh fuel. Eliminate the bubbles once again and start the engine. Take it for a quick test run and Bob's your Uncle.
A polishing system is your call.
Edit: I just saw the final post (shrug
