Deb2021
- May 31, 2021
- C-26
- Pip
Went to head out this morning (solo), slipped the lines and hopped on the boat. Tried to shift into reverse as the boat is slipping away from the dock and it wouldn’t shift into forward or reverse. Diverted disaster by using thrusters and boat hook and getting tied up again.
While the boat was still running, I managed to check throttle in idle and was able to move the lever forward and back but popping out of idle I was not able to engage either forward or reverse. I have since removed the casing, hoping to see something obvious but when you don’t know what you’re looking for it’s hard to tell what is obvious.
Any thoughts, references, YouTube’s that you can suggest? Any help is appreciated.
Deb
Deb
