Throttle/shift control issue
DBBRanger
R-25 Classic
Still Crazy
My Ultralflex control has been steadily getting more difficult to move. Going from neutral to transmission engaged is OK, but adding a small amount of throttle is difficult. Once the throttle is engaged, it moves smoothly. It turns out, there is a detent ball that holds the lever in the "transmission engaged/throttle not engaged position". Getting past that detent is the problem. There is an adjustment on the clutch but that screw is all the way counter clockwise and in fact is loose within its holder. When I push the button to engage only the throttle, it moves real smoothly. I believe that's because the detent ball is not engaged. There seems to be plenty of grease.
Anybody have any suggestions? The only contact with Ultraflex is through email and that is to Italy - so I'm not holding my breath for a response.
I have contacted Uflex on several occasions and found them to be quite responsive and very helpful. You can contact them at:
UFLEX USA Inc.
6442 Parkland Drive
Sarasota,Florida 34243 - USA
Ph. (941) 351-2628 - Fax (941) 360-9171
e-mail: sales@uflexusa.com
Eric
Tugger Toy
2006 R-21 Classic
Thanks for that - I'll give it a try!
Doug
