thru hul sealant
Jon
C-288 C
I have a leak in the exhaust thru hull fitting. Can you tell me what type of sealant was used or what type I should use to reseal?
Jon
Hi there
We use a urethane sealant on the thru hulls. You can use a 4500 or even 5200 to reseal the thru hulls.
Thanks. Any advice on removing the old sealant??
Jon
Jon
Razor blade type scraper. If you have bottom paint it will need to be ground/sanded back so the sealant gets a good purchase to the hull. Of course, then touch up the bottom paint.
david
