Metric Rider
- Nov 6, 2012
- C-248 C
- FMLT2568L708
- Lil Toot
While changing the sacrificial anodes on the thrusters I have run into a problem (apparently of my own making!).
I was successful on removing the centre bolts and then I was able to remove the old anodes with application of some penetrating oil and light prying with needle nose pliers(being careful not to insert the pliers too far so as to avoid damage to the threads). I cleaned the surface behind the anode with emery paper to ensure good contact with the new anode. The front anode was reinstalled with little difficulty (I used blue threadlock and tightened enough that there was no movement between the hub and the anode)
When installing the new rear anode in spite of trying to be careful I have somehow managed to strip the thread in the housing ( I believe it is brass). There is some thread left but not enough to properly tighten the bolt. I am hoping I am not the first person to have this issue and am looking for solutions:
1) can I use red threadlock or some other material on the bolt threads that will hold the anode in place
2) or can I use a slightly larger bolt with maybe a coarser thread
3) or heaven forbid, replace he housing!
Also have the following questions:
a) Since I could find no specified torque setting for the bolt am I correct in assuming it need to be snug enough to keep the anode from freely spinning so there is adequate contact?
b) Is it possible that there was debris in the end of the bolt hole that prevented the bolt from tightening down the anode before it stripped the thread?
Thanks in advance for any suggestions / solutions
