Favunclerich
- Jan 27, 2010
- C-248 C
- FMLT2542G708
- Roam (2008 #42)
It's a cold Michigan morning (0 degrees F) and, as a retired automotive engineer, I think that it would be useful to collect some data on tongue weight and its effect on sway. Hopefully, we can use this information to develop better recommendations for Ranger Tug owners to set up their trailers to tow safely and without sway. In the interest of full disclosure, my previous job involved did not involve towing, but rather safety regulations for safety belts and air bags. I did have access to the industry experts on towing.
The problem is that there are currently multiple, conflicting recommendations as to what is an appropriate level of tongue weight. Tongue weight is actually a measure of the location of the center of gravity of the boat and trailer. Sway starts when there are uneven side forces and is more readily dampened with a forward center of gravity.
The upper limit of tongue weight should never exceed the limits specified by the truck, hitch, ball mount and ball manufacturers. There are likely two limits; one with weight-carrying hitches and a higher limit if you are using a weight-distributing hitch. Not only are these limits based on the structural strength of the parts, but also the safe handling of the truck. Excess tongue weight reduces weight on the front wheels. Not only will this affect steering, but your headlamps will be pointed up into the trees. Weight distributing hitches can reduce this effect by the use of springs that apply a moment and thereby transfer load back onto the front wheels.
The conflicting information surrounds the lower limit of tongue weight. Some vehicle manufacturers specify 10-15% tongue weight. One manufacturer specifies 8-12%. Trailer manufacturers often specify even less; typically 6-10%. I saw one that went as low as 5%.
I tow Roam (a 2008 R-25) with about 860 lbs of tongue weight and a total weight (half tanks, moderate amount of cruising stuff) of 9400 lbs. This works out to 9.1%. I've towed her for over 10,000 miles using a weight-carrying hitch behind my 3/4 ton extended cab Silverado, over mountains and with some significant crosswinds. I have never had an issue with sway. In a recent post, the owner of an R-27 reported sway issues with 460 lbs of tongue weight and a total weight 10,780 lbs (4.3%). Therefore, 9.1% is adequate to prevent sway and 4.3% is not. This is limited data and a very wide range. A good, data-driven recommendation ought to be able to more closely specify minimum tongue weight.
I'd like to collect data as to what Ranger Tug owners are using and share the results on this forum. I can also provide the results to the industry towing committee.
I'd like to hear from Ranger Tug owners who have carefully measured their tongue weight and total weight. You can post either on this forum or send me a Private Message and I'll keep it confidential. I'd like to know your boat type, total weight (boat and trailer and stuff), tongue weight, truck type, and if you are using a weight-carrying or weight-distributing hitch. Please tell me if you've experienced any sway. If you have not experienced sway, please only report if you have towed at least 1000 miles including hills/mountains and significant crosswinds.
Thanx, I'm anxious to see the results.
Rich
Rich
