commander bill
- Feb 4, 2009
- C-248 C
- Lenabell
I use Mercon abative bottom paint. It is easy to touch up each year and is designed for someone that keeps boat in & oout of water for extended periods. However, it is soft and the trailer bunks take off significant amounts of paint each time I load or unload. Boat is very difficult to slide into water or back onto the boat. Part of the problem is all local ramps in my area are for smaller boats such that I can not obtain desireable depth/slope at ramp.
I noted that you can buy bunk slides which are supposed to make th eboat hull slide onto or off the trailer bunks easier. Apparently the ease is due to them being wet. That is after you load the boat and the slides dry off the boat will stay in place & not slide around on trailer. have any of you guys used these with a Ranger. The slides I see advertised are all designed for smaller boat bunks (3" wide X 15" long) and you must install multiple sections on Bunk. Also, do they install over carpet?
