snydzy
- Jan 29, 2015
- R-25 Classic
- FMLR2517L213
- Tugster
Just replaced for the third time (this season) broken brake line(s) on the aluminum trailer for my 25SC. Deflection of the front wheels while cresting on steeper boat ramps is causing the brake lines to shear on the trailer frame. The tandem axle trailer I use has torsion axles. Lots of positives about torsion axles over traditional leaf spring setups. They tend to be quieter because of the independent wheel movement, more responsive to small bumps, and because of the rubber tend to dampen vibration better..... but.....
The key with multiple axles is making sure they will share the load. There really is no point to having multiple axles if they don’t work together. Call it “Load Share” or “Equalization”. Since the road is not always flat, and the trailer not always level, the axles need to accommodate uneven ground while still sharing the load. That means, as you go over a bump, or crest on a steep boat ramp, the wheel up on the bump can end up carrying nearly all the weight, with the other axle(s) carrying much less. It’s only a short time overload, but obviously severe enough to cause enough deflection to shear the brake lines. This time I turned the front caliper adaptor ports to face aft, rather than perpendicular to the wheel, which should allow enough clearance to alleviate this issue.
But it did get me thinking,... almost all the trailer tire problems I’ve had, (and I’ve had a few), has been those front tires on the tandem axle setup. They have been the ones that have failed, blown out, blistered, or worse...abused more because of this kind of overloading, and who knows what internal damage is sustained....? Is it better with a triple axle set up? Leaf axles? Without load sharing, I don’t see how. What are boat trailer manufacturers thinking?
