The transducer on my 2016 RT 25 has a couple of things I would like others thoughts
1) depth readings - the readings are accurate however there are tomes when the readings flash on and off. It is difficult to reproduce at will. Sometimes it does and sometimes it does not. Flash. I checked the fluid level a,d the seal with the hull. All seems fine.
Is this normal operation or ..
2) the transducer has an Audible clicking noise when powered . Any suggestions or is this normal
Regards
Bob
Regards
Bob
