JamesTXSD
- Nov 23, 2008
- C-24 C
- Non-Fluid Motion Model
- C-Dory 25 (sold)
- Wild Blue
That PDF that Brian posted shows the "weight as tested" at almost 2,000 pounds more than the published "dry weight." And, you know on a test boat that they will be keeping the weight light for the best performance numbers. Add another 2,000 pounds or so for a trailer and you are around 10,500 pounds. Put some cruising gear onboard, and it would be easy to be on the far side (perhaps far on the far side) of 11,000 pounds. 150 gallons of fuel will weigh 1050 pounds. 40 gallons of water will be 320 pounds. When we tow boats, we try to have a minimum amount of fuel onboard - no advantage to carrying that extra weight. And since fuel is almost always less expensive on land than on the water, fuel up a trailerable boat just before you launch.
Best to err on the side of caution with towing capacity. But, for "curiosity sake" to determine the weight of the boat on the water, my "swag" guess would be well over 9,500 pounds. Some travel lifts have a way to determine weight when the boat is pulled for any maintenance.
I've never come across a boat that weighed as little as the manufacturer's published weight.
