Cutwater28GG
- Jan 14, 2016
- seattle
- C-28
- Non-Fluid Motion Model
- Cutwater 28
- Living The Dream
So I have a small leak at the fill cap at the outside helm station. I’ve read online that this can be caused by the fill cap not venting air causing pressure to build up.
I also just undid the fill cap slightly at the inside help and got some air bubbling out which I then quickly tightened the fill cap to stop
Should it be possible to undo these fill caps without causing an airlock? I want to make sure what the procedure is to top off the oil before I do something to cause an airlock and a need for a bleed.
What level should I top them up to?
What oil should I use? Sorry I don’t appear to have a manual for the helm.
