GaylesFaerie
- Jul 20, 2020
- C-28
- FMLT2701D112
- Gayles Faerie
Hi, I've looked in the manual and I can find no documentation of this fault code. Gayle's Faerie is a 2012 R27 Classic with a Dometic Heat Pump. When I turn the unit ON a fault code will appear on the control panel where the first and third symbols are indecipherable and the middle symbol is a 5 or S. I turn the unit OFF. I turn it on again, and the unit shows the ambient air temp in the cabin and begins working. The water temp is about 65 degrees, the seacock is open, and while running a nice steady stream of water is exiting out the port thru hull. The unit will run for about 10-15 minutes pumping out cool air - nothing bone chilling but clearly cool. Then the unit stops and displays the Low Pressure Fault code LPF. I turn the unit OFF. I wait 10 minutes. Then the whole sequence of events will repeat. Any thoughts or ideas appreciated. Pics below. GF
Code on initial start: https://photos.app.goo.gl/7e3Uwg11QCPWiQVBA
Unit running ok: https://photos.app.goo.gl/qutG2Db7LFrPr75e6
LPF code: https://photos.app.goo.gl/zfEg6gnEsxhJkfgW6
