GaylesFaerie
- Jul 20, 2020
- C-28
- FMLT2701D112
- Gayles Faerie
This is beginning to feel like those full body scans some doctors recommend one not have because you may find plenty of anomalies to worry about and you may want treated but they are actually benign and if you never had the scan all would be fine...
As part of Spring prep I was testing the resistance for various items in the bonding system after adding a transom anode. Long story short, I'm showing Ohm readings that gradually go up the farther away from the batteries I measure, to the point I'm seeing 2.9 Ohms on the underwater metals (all 3 seacocks, the rudder and new transom anode). I secured the red lead of the meter to the negative battery post of one of the 3 house batteries and probed down stream with the black lead. Here are the readings all of which produced a tone on the meter as one gets farther from the battery:
Neg. battery post to the lug of the neg. cable that is attached: 0.0 Ohms
Neg. battery post to the lug on the other end of the neg. cable attached to the shunt: 0.2 Ohms
Neg. battery post to the lug on the other side of the shunt: 0.7
Neg. battery post to the post on the neg. bus bar receiving the neg. cable from the shunt: 1.8 Ohms
Neg. battery post to the bonding bus bar which is connected to the neg. bus bar: 1.8 Ohms
Neg. battery post to the Rudder or thru-hulls: 2.9
I also found a green bonding wire on the House PDP and it read 0.7 Ohms
Temperature was 45 degrees.
All batteries are fully charged.
All connections are tight down the test line.
No visible corrosion anywhere except the rudder post woven strap.
No extensions used on the VOA leads.
BB Marine has noted that bonding system readings for all components should be 1 Ohm or less which is what I was hoping for. Do my readings mean I have bad wires in need of replacement? I don't fully understand what I'm seeing or the implications. Comments welcome. Gary
