Useful things to take photos of a R29S being built ?
baz
Subject: Useful things to take photos of a R29S being built ?
I'm going to the RT factory where the R29 S model is built. What would be useful things to photograph while I'm touring about the factory ?
I've done this for other RT model builds and always find I've missed one or two important things. If you were to photograph what would be the essential things to focus on ?
Thanks....
Barry, does this mean you’re joining the ranks of R28S owners? I’d suggest taking photos of all the water lines, black water lines and if you can and or want to have a black water tank filter installed while the boat is being built. Also photos of any vent or discharge hoses as well as the area around both the bow and stern thrusters from the inside of the boat.
Jim
Thanks Jim..... I'm doing my due diligence before leaping. My boating requirements have changed from a year ago and I'm trying to fully understand this before making the decision to move to a R29 S model.
Building a photo album for the R29 S build activities and capturing images of its areas that become hidden after full assembly is a pre-requisite no matter what I decide.
Thanks for the advice on capturing the areas you've mentioned.
Adding any extras during the build activity is always a challenge with RT. Adding after the factory has done its work is another matter and is more easily done without any pushback from RT factory people. Andrew has only so much sway in getting the factory to change or alter something.
The black water (holding tank) vent filter is a good suggestion for sure. What brand/type would you suggest ?
Jim: If a holding tank vent filter were to be installed at factory, wouldn't it be hidden eventually as the boat is built up. I'm assuming a filter need replacing now and then, right ?
I installed a black water tank filter just below where the vent line exits on the starboard side of the boat. To access the area you go into the cave, unscrew the access gent for the A/C and then disassemble part of the wall and ceiling to be able to get to the white vent line that the filter gets attached to. It’s easy enough to do it just takes some time and patience. I my filter was originally a Dometic inline filter that I now re-energize with fresh charcoal every year.
Jim
Barry,
My thought is not so much as a pic but a item for discussion with RT: water pump.
I replaced the factory installed pump with a Johnson Aqua Jet Flowmaster WPS 5.0 variable flow demand pump. Now I no longer have the "thump"!
Also, if you've never had occasion to service the filter on your current water pump, you should. Ours had a fifty-cent size accumulation of plastic shavings from fabrication filtering. This probably applies to anyone who has never service their pump filter.
Bob
Bob:
You're absolutely right about the fresh water pump. The thumping and banging sounds are simply awful on my R27/OB and more so when using the head sink especially. The cabinet under the head sink kind of acts like a boom box. :roll:
I was at the R29 S/CB & R31 S/CB factory in Monroe today and captured around 50 photos (without Andrew getting in the way :lol: ). Actually, Andrew was very attentive to where my camera was pointing and would quickly remove himself from the scene.
Gosh, there's so much more space in the R29 vs. the R27/OB model. The Cave is simply cavernous, wider and deeper and can easily accommodate 2 young children, and of course the dinette berth is wider also. I would have no trouble going into the end of the Cave head first to get at things.
The Webasto heater is located under the Refrigerator and with the Refrigerator removed (just 4 screws) and pushed aside (I noticed there was sufficient wire slack for this) access to the furnace is excellent.
Access to the Macerator, holding tank and associated pipes are all under the aft section of the island berth and easily accessed with the big lower draw removed and raising/removing the aft section of the 4" form mattresses.
The engine access is excellent and completely outside of the cabin and is fully contained in its own liner. The only opening I saw between the engine bay and the cabin area was a slight opening at the Cave's aft area for allowing fuel lines and some wires to route into the engine bay area.Engine oil filers (two of them), fuel filter raw water strainer, and raw water impeller pump and housing are all within easy reach. Without a Genset sitting aft of the engine there's plenty of room for a person to stand while working on the engine. One actually stands on the Genset tray. Behind this tray there's full easy access to rudder arm, autopilot hydraulic piston, rear thruster and hydraulic fluid tank. It's simply cavernous back there.
Batteries are somewhat hidden in and in forward sections of the port and starboard cockpit lockers. The battery charger is on full display in the starboard locker, but was unable to locate the Inverter.
Storage under the helm seat is very very generous, as are the two hatches to storage under the starboard side forward step (where sink used to be or where the aft steering controls would be located).
The two metal stanchions supporting the cockpit hardtop are very sizable and feel very comfortable and stable when grabbed.
I looked carefully on how best to have a full cockpit enclosure made and see that the cockpit hardtop sides aren't vertically aligned with the cockpit port and starboard side, nor is the aft lip of the hard top vertically aligned with the transom. Thus, without extending the hardtop in some way the full enclosure will have sloping sides and a sloping aft panel. The aft panel will also need to have an opening panel that matches the position and dimensions of the transom flip seat so that the seat can be deployed when needed. I've contacted Dave at King Marine Canvas and he has said no problem and he can easily template the enclosure for me and deal with the slopes and the aft panel issue for the transom flip seat. I'm very keen on having a full cockpit enclosure as it will be very useful during the PNW winter months when I cruise about. Incidentally, the Webasto heater provides heat to the cockpit area so that's a very nice feature to have.
Everywhere I looked and stressing panels and flooring felt rock solid.
I love the way the head door opens inwards rather than outwards on my R27/OB. So much more convenient and I would venture to say, safer when the boat is rocking about.
The helm console is nicely laid out and the one under construction I was viewing had the twin chart plotters which is one of my requirements as well.
The rudder is of sufficient size IMO and is around 1" thick. It looked very substantial and suspect quite heavy as well. I recall the rudder on my R-25 Classic which had a much smaller rudder area and was referred to as being too skinny by many people. The skinny rudder meant steerage was compromised some at 4 kts and below which when docking presented issues. A fellow R-25 Classic owner (was over 90 yrs old) at my marina actually was so ticked of with his skinny rudder that he hauled his boat out and welded (maybe bolted) a plate to double the surface area of the stock skinny rudder. :lol: He was so excited about his mod and kept telling me he does not use the thrusters at all when docking.
My overall sense was that the R 29 S/CB are well built boats with much attention given to easy maintenance along with its modern design. It also visually looks a great deal bigger than my R27/OB even though there only 2' in LOA difference. The biggest aspect of size comes from the R29 having a 10' beam.
I will post a link to my R29 S/CB photo album in a followup posting here.
Nice pics, Barry… as usual!
The R29-CB in Claret Red is nice, but I recall you saying you're interested in the Hero Red... is that right? They both look nice, but I really like the Hero Red! Looks like a lot of boat! If you plan to go back to Monroe for another visit, let me know... I'd love to tag along.
Bob
Yes, Hero Red is my choice. You're probably nearer to the Monroe factory than I am. Sure, if I go again I let you know.
RT has expanded the Monroe factory some and now can keep all the wood working activities separate form the fiber glass activities. Thus wood dust and fiber glass dust do not mingle.
I have to wonder just how many separate pieces it takes to build a R29 ? Andrew had no answer to this question. :lol:
The Monroe factory builds the R29 and R31 models and collectively RT pushes out 4 per month. They are behind on R29 schedules by around a month which at this time the R29 is RT's most popular boat and equal to their R27/OB's popularity. RT would like to be pushing out a combo of 7 R29/R31 per month so they can make money. :roll: 😉
Barry,
I was pretty set on having a second helm station chartplotter when we ordered our 29CB but, after doing some research, we decided to go with another alternative.
Even though we have some built in redundancy for navigation through the command bridge helm, I wanted to have the ability to navigate and check weather through a completely independent system at the lower helm. I didn't want to have to go the CB in bad weather or attempt to use my phone to navigate if we lost the primary chartplotter at the helm. We have decided to go with a 12.9" iPad Pro mounted next to the helm chartplotter. It will also give us the added flexibility of functioning as a laptop underway or inport. I don't want a bulky mount that sticks far off the dash, but the case/mount in the attached link looks pretty flush and allows for easy attachment/removal of the iPad.
(https://www.studioproper.com/products/c ... gLUXvD_BwE
I haven't decided if I am going to run power to the iPad from behind or charge it off the dash.
There are added costs for this redundancy (cellular service or data fees if we use a phone or Mifi hotspot to get cellular access) plus subscription fees for navigation apps like Navionics, but the added cost of a 2nd Garmin chartplotter is pretty steep, too.
mjq1987:
For me the convenience of having two chart plotters on the helm console pretty well trumps the extra cost IMO. It does provide redundancy to some extent, although I will admit it's possible that both chart plotters could fail simultaneously. In this event having a device such as an iPad or a smart phone (and of course some paper charts) should be onboard. I already have iPad and iPhone so their cost is already covered some moons ago. 🙂
When a 2nd chart plotter is installed by factory the Auto pilot and Volvo engine displays are relocated to port side of the 2nd chart plotter making the overall helm console more visually pleasing to look at and the two small displays (auto pilot and Volvo engine) being further away from direct light from the starboard window lessens the reflections on these two displays and for me are more readily viewed clearly.
