Submariner
Channel Surfing
- Feb 2, 2020
- Everett, WA
- Website
- www.letsgochannelsurfing.com
- R-27 (Outboard)
- FMLT2702C021
- Non-Fluid Motion Model
- https://tinyurl.com/yrv84xdm
- Channel Surfing
knotflying":3th201qp said:The Yamaha has a trolling mode that permits the RPM's to go below 800. I couldn't tell you what the minimum speed is that you will get. As you know lots of factors will affect speed
I tested this out earlier this week. Using the "Troll Mode" on the Yamaha F300, I could drop the RPM's as low as 600, and the boat was moving at 2.7 knots (at slack high tide). That was the slowest I was able to move. I could then tap up on the RPM's on the Yamaha display, increasing the RPM's ever so slightly, to get a little more speed (without moving the actual throttle).
NWDiver pointed out that the newer throttles from Yamaha (which the newer RT27-OB's come with) should have the troll control feature on the throttle. This enables the Yamaha to shift into and out of gear as necessary to achieve troll speeds even slower.
Anyone else with a newer RT with the outboard played with troll mode?
I've got the 9.9 kicker, so that's my go-to for trolling. But I don't have that awesome wrap-around swim step of the RT25.
