BB marine
- Feb 1, 2016
- C-26
- Non-Fluid Motion Model
- Grady White 208
- PORT-A-GEE
When I installed the 2000W inverter I wired the three position AC switch to power both sides of the box in the inverter position. My main reason for installing it was to have outlets- coffee maker, Microwave/oven and stove use, while cruising. The stove is on one side of the panel and microwave/oven and outlets on the other so I needed to wire both sides. I plan on using power management to prevent a power overload. Turn breaker on when in use turn off when not. Max output continuous is 2000W with a 4000w surge. The Kisea has a built in overload protection that will shut it down to prevent damage. I don't want to test that.
Brian Brown
26 Cutwater
PORT-A-GEE
Brian Brown
26 Cutwater
PORT-A-GEE
