stwendl
- Aug 11, 2015
- C-28
- FMLT2719J516
- Cataleya
2016 r27 supplier inquiry
I was wondering if someone at the factory could provide with sources or part numbers for the hose and shutof valve which is used to feed coolant to the water heater and internal heat exchanger under the steering station.
Since engine coolant runs thru that I would assume it has to withstand the particular make up of the engine coolant and furthermore prevent engine coolant from being contaminated.
The re are two shutoff valve on the port side of the engine two completely isolate the water heater and cabin heater from the engine. Just curious what procedure is used to purge this part of the system from air if it ever becomes necessary to do so
