vinyl trim
csj2018
C-242 C
Moon Shadow
We have a 2018 R-23 and the vinyl trim has come loose below the front window. What might be the best glue to use to use for this repair so that it doesn't happen again?
Thanks for your help.
That happened to my window trim also
I tried a few things that didn’t work
Then I found the solution...patience.
I started on the left side and applied Gorilla Glue to about 3 or 4 inches, applied mostly to the bead on the vinyl trim. Then I applied pressure and used a heavy weight to sort of keep it in place. I left it alone for at least 24 hours then...
I did it again with 3 or 4 more inches. After several days, not consecutive, just when I was at the dock messing around , I was finished all the way across the bottom
It worked, but it took a little time.
Dear Ernie,
Thanks, I'll give it a try.
