davecook
- Jan 1, 2014
- C-28
- FMLT2721A313
Has anyone had a fault code of '' power failure '' come up on the 4 '' Volvo screen , when starting . It beeps and makes you clear the code ; before you are able to start engine . Anyone find out the cure to this problem ? Also have low coolant warning ( level 2 '' below coolant cap top ) I will try adding a little Volvo pre-mixed coolant . Also on first fuel fill up , the gauge still reads 1/8 tank - I put in 55 gallons . The gauge was working for the last 3 weekends .I found fuel multipoint calibration and fuel tank calibration , not sure if anyone has run into it , Thanks to everyone for reading this , and hopefully someone will have Thanks Dave Cook
