AGLyme
“Sweetie” RT 31cb
- May 15, 2024
- Lyme, CT
- R-31 CB
- FMLT3129J213
- Just contracted to buy it, changing nm.
When starting, ignition is turned on, there is piercing noise, engine start occurs, ignition noise ceases.
When turning engine off, the ignition noise comes on until the ignition button is pressed.
Last eve, I went to turn the engine off while anchoring, and after I pressed “off”, the ignition sound did not happen.
Ditto when I turned the engine back on. Ignition pressed, green light turned on, No ignition sound. But the motor started after “start” was pressed.
Engine is running fine, shift lever was in the neutral position. The only issue is that the noise is no longer happening.
Is this a problem ?
Thank you.
Is this a problem ?
Thank you.
