harbournate1
- Jul 25, 2021
- C-302 SC
Recently took our R31CB out for a cruise and was unable to go over 1800 RPM's. No alerts or warnings and all gauges were normal. Called in our local Volvo tech to troubleshoot and he found that the turbo was siezed. He has seen this before and it is apparently caused by minimal elevation between turbo exhaust elbow and water line in the wet exhaust. This causes condensation to form in the turbo and it reacts with the buildup on the vanes and causes corrosion which causes the vanes to stick. This same situation has been mentioned on this forum as having caused water ingestion to the engine. According to Fluid Motion the engine installations are all reviewed by Volvo and deemed adequate. It seems that if that were the case that this would not be a problem. This is the 3rd turbo on this boat and now it has to be reconditioned (hopefully).
Has anyone come up with a solution to this problem?
