Alpina":1pw77tna said:My generator has an engine anode so I am wondering if the Volvo Penta D4-300 has them also? If so where might they be located?
Franco
Gin":23gdlndm said:Kevin, do the newer D4-300’s have anodes? I was told that the engine in my R31, built in late 2018 as a 2019 model, does not have anodes, and I haven’t been able to identify any. But I’d like to make sure I’m not missing a maintenance item. How can I do that? Thanks!
Gini
Thank you.TBates":wiayzzat said:Hello,
The Volvo D4 and D6's originally had two engine anodes installed (one on the heat exchanger and one on the charge air cooler). Volvo removed the anode from the heat exchanger, but kept the anode installed in the charge air cooler. Shortly afterwards the anode from the charge air cooler was removed. This all took place between our 2015 and 2016 model year boats, however it's best to check the engine on your boat to verify which anodes, if any, you have onboard. Please feel free to shoot me an email with any questions.
Thank you,
-Tim
