I beleive the seakeepers are designed to reduce roll for every (all three) cases:
1. when stationary
2. when trolling, and
3. when cruising.
(Maybe most seakeepers videos are made while stationary because it more clearly demonstrates the seakeeper On and Off cases)
The interceptors will only work for the 3rd case (at cruising speed) because they need significant water flow to work.
So if you want roll reduction while trolling and/or stationary, you need a seakeeper.
Personally, I don't care so much about limiting roll when stationary or trolling. I want to limit roll when I've got a 4 hour crossing in rough waters with waves on my beam. Yes, seakeepers would do the job (I think). But what caught my interest was the claim that interceptors, with their fast response time, could also limit roll at cruising speed. Given that you need some kind of trim control (horizontal plate trim tabs or vertical plate interceptors) in any case, my question is; if you already have interceptors (or could spec them on a new boat) and if they do in fact limit roll while cruising, then why pay for a seakeeper? The additional cost for the electronics to upgrade basic interceptors to include auto pitch and roll control is a fraction of the cost of a seakeeper.
So, that's my quetion: At cruising speeds, can interceptors with auto roll & pitch control match seakeeper performance?
If not, I'd still consider something like the Lenco Auto Glide Trim Tab Control System mentioned a few post ago because:
- it works even with horizontal plate trim tabs
- it includes left and right trim tab position indicators
- it effectively auto adjusts for pitch
- it may not work well enough to continuously counter roll due to broadside waves, but it will auto level the boat to adjust for uneven loading (people, fuel, water, holding tank).
Or so it seems from the sales info.
