bbrh842
- Jun 15, 2009
- C-248 C
- (2007) Tug O' War
My personal opinion after using the Wallas for 4 years...............
I seldom use it for cooking, but use it mainly for heat in winter.
It is hands down the best way to heat the boat at anchor.
The reset issue is a non issue.
The only time I had to reset the stove is when it was new.
Most likely someone at the dealer attempted to start the stove multiple times with no fuel in the tank.
The exhaust pipe under the stove does get hot, but not hot enough to start a fire.
It will get hot enough to melt plastic, if a platic item is in direct contact with the exhaust pipe.
Don't store plastic items or beer under the stove, and you will be fine.
Store pots and pans under the stove, and other items that don't mind heat.
One thing I wish the factory did different with the Wallas, they should plumb it into the main diesel tank.
And maybe they to on new model tugs.
On my 2007 R25 the Wallas has it's own dedicated fuel tank that holds about 3 gallons of fuel.
Three gallons lasts less than 2 days if you are using the stove as a heater, and the tank is a pain to refill.
