Try closing the seacock while your boat is at dock and then unscrew the sea strainer cap and set it aside. Now open the seacock lever and see if you have a full flow of sea water. If you do then your problem is north of the sea strainer. If you have no flow then you may have a clogged or blocked thru hull fitting or hose and the problem is south of the seacock. Close the seacock lever. If the problem is south of the seacock, with the seacock closed unscrew the hose clamp and work the water hose loose so you can try and clean the clog out. I've had this happen with seagrass. Whatever the final problem is let us know what it was and how you fixed it.
