jimbeam
- Aug 21, 2019
- C-248 C
- FMLT2545G708
- waite & sea
Gotta leak somewhere in the stern and on both sides of the boat. It's running into the bilge and activating the water pump once in awhile. I found water way low on the port and starboard side. Appears to be rain water but unsure. I didn't taste it to see if salt water since it happens when it rains hard. The stern thruster housing appears tight and dry but a good amount of water below it. It runs through 2 drain holes on either side of the engine compartment back bulkhead just above both sides near the shaft but a good foot from the shaft and stuffing box. I checked the stuffing box and dry. Anyone have any ideas?
Ranger 25 2008. My next step is to take off all fittings near the stern and rebed them but the water is coming in to where it fills the bilge and activates the pump so I figure wouldn't be a leak thru a fitting.
Jim
Jim
