Gin
- Dec 12, 2012
- R-31 S
- Echo II (2019)
I'm working on my checklist for winterizing procedures. We plan to use the boat through much of the winter, and keep heat aboard (in the engine compartment as well as the cabin) at the dock. But we likely will err on the side of caution and winterize the water, head, and raw water pump systems . If there were a power outage and we were to loose power at the dock in a bad freeze, we could quickly winterize the engine, and have everything else done. Meanwhile, for our winter purposes, we will be fine without the other systems.
I've read everything I can find on the forum about winterizing, but nothing that suggests what the Seaward water heater manual advises about winterizing. It says to run antifreeze into the holding tank then through the system at each faucet. Then, after turning off the faucets and the pump and leaving the faucets open, "Locate the water drain and pressure relief valve and let all water drain from water heater until empty. Leave water heater drain and pressure relief valve open over winter.
I read different advice about whether to drain the water heater. But I haven't seen anyone say to leave the drain and pressure relief valves open all winter. Does anyone do that? Is it unnecessary? Anyone think it would be ill-advised for any reason?
Gini
Gini
