Commander Ed
- Jul 16, 2009
- C-248 C
- Sea Dragon
I have an R-25, and have had an issue with water in the bilge. Not a lot of water - but more or less constant about a quart per day - more if I take her out. My original issue was the bilge pump running continuously, and eventually had to change the pump. (Thanks Andrew for your help on this one - and the rewireing advice to the start battery.) So my question is - does anyone else have this experience? My broker more or less says "boats leak a little", but this seems too much and too consistent. All I need is another bilge pump failure, and potentially a bigger problem will follow. I have only had the boat 3 months, and when I bought her, the bilge was dry. More data- water is salty therefore not from one of my freshwater sources, also the sea strainer and A/C lines are not leaking.
