Water in cabinet under radio in R21EC 2010
C-24 C SE
FMLT2107G910
SeaSpiritII
After nearly every cruise we find a very small puddle of water on the left side of the cabinent under the radio in our R21EC 2010. There is no water on the cabinent floor over the water tank (above the radio cabinent) ...only on the bottom of cabinent under the radio. Has anyone else ever experienced this? We estimate our fresh water tank is about half full - but that is a guess. Any suggestions welcome. Thanks.
I have a 2008 R21-EC and I get the same thing as you but bilaterally. That is, I also get water in the starboard cabinet under the engine instruments. It is worse after rough water. For that reason, I have discounted the source as being the water system although I have not done a taste test. My supposition is that this is water that infiltrates through the bolt holes which attach the rubber bumper down both sides of the boat. There are dozens of these and each could be a potential portal of entry. I don't know yet if I found a fix but recently I checked each screw for tightness and they were all tight. That is, they moved only fractionally. My plan is to re-check after next cruise and if I get water again, I will try a bead of silicone next. I'm very linear.
Post here any progress you make as it would be nice to find a fix for this annoyance.
