kjoverbeck
- Sep 12, 2020
- C-28
- FMLT2704E415
- Cheers
2015 R 27
I installed the trim tab side plates and was on a test run when the "water in fuel" alarm went off. I stopped, acknowledged it and continued back to the slip with no problems. That night I read on this forum that this can sometimes happen when there is no problem. The next day I returned to the boat, started it and let it run for about 10 minutes, rocking the boat side to side. No alarm. This boat had all filters changed before I bought it. I have put about 65 hours on it for a total of 435. It has always been under cover, never exposed to rain and all diesel bought at high volume fuel docks. I really don't believe there is any water problem. However if it happens again I will check the water separator as suggested. My main question is just how do I remove the connector on the bottom of the separator? It looks like there is a small clip but I can't see it without a mirror. Surely it can't be that difficult to do. Any thoughts or suggestions would be appreciated.
Thanks, Kent
Thanks, Kent
