Water Ingression to the Engine - Before You Leave the Dock
racurry@unb.ca
R-23 (Sterndrive)
Water Weaver
I wanted to start this Topic to amalgamate our conversations which are split among several topic titles when you search "hydro lock", its variants, and other related key words. I am going through this major problem currently. There is good information on this Topic in Tugnuts - BB Marine, Osprey, Sine Wave for example.
I am not a mechanic and my starting explanations will be simple, but after >3000 NM over the last 10 months on my Cutwater, I have experienced a few things and this is the biggest issue that every Cutwater owner needs to know today. The experts can add more as the topic discussion grows.
To begin, Fluid Motion does not provide this information in any manual or webinar on the very real, dangerous, and expensive problem of water ingression into your Cutwater's inline diesel engine. My boat is a 2016 C30 Sedan with a Volvo Penta D6-435 with a wet / lift exhaust.
Challenge #1 - Engine won't start: If your engine won't start but you can turn it over, close your seacock on the engine water intake before you try to address the engine problem. The system is drawing water when the engine is turning over and that water has nowhere to go except to accumulate in your muffler where it can't get discharged offboard without the engine running. This means water is collecting and backing up into your turbocharger and then your engine. Searching around, I read that 15 seconds is the maximum time you should turnover your engine without it starting and your seacock open. The added challenge in this situation is that your engine can turn over, but it may not have enough cranking power left to start the engine, which leads to the >15 seconds of trying. You won't readily know your battery power challenge without an accurate power level reading from the battery itself, plus experience / knowledge of this engine-battery relationship for your boat.
Challenge #2 - Anchored in Rough Waters: As your boat rocks at anchor, the boat exhaust flapper on the outside of the hull, where the exhaust hose connects, should close to prevent water ingression. Check it at dock and if it flaps easily, then when you are anchored in rough water without your engine running, water is entering into the exhaust hose. Next, check your Cutwater's exhaust system layout. On my boat and many others across the Tugnut world, the design is NOT sufficient to keep that ingression of water from reaching your muffler. My exhaust line rises a maximum 14" above the water line in a straight-line (72") with no check valve before it drops directly into the muffler. When the boat is rocking and water enters via the flappers, it is accumulating in the muffler, and once filled, the rocking can lead to water enter into the turbocharger, which in my case is a <12'" rise over 23" length of hose, and then into your engine. I'll post some diagrams and pictures of my boat. There is more to read in other Tugnut threads.
Challenge #3 - Towing Your Boat on Water Part 1: As occurs in Challenge #2, towing in rough waters creates the same water ingression via the flappers-exhaust hose-muffler-turbocharger pathway.
Challenge #4 - Towing Your Boat on Water Part 2: Your water intake for the engine cooling system most probably draws water from a forward opening on the hull, i.e., the opening is towards the bow. When towing on water, a pressure gradient is created which pushes water through the seacock all the way to the muffler in some instances. Again, once your muffler is full it back fills up to the turbocharge and then your engine. There is a good Tugnut thread about this too.
Challenge #5 - Your Shaft Seal / Stuffing Box: This bearing system is water cooled via a line from your engine's water intake system. In another thread, you can read about incidents where that water can be syphoned back into the muffler and then the engine as described above. I don't fully understand his one, but others in Tugnuts describe it well.
Solutions: I can only offer the easy ones to start.
TOWING ON WATER - Any towing on water demands that your seacocks are CLOSED. I don't have a solution for the Flapper issue yet.
ENGINE TURNING OVER - If your engine doesn't start after 15 seconds of turning it over and your battery still has enough power to start the engine, close the water intake seacock before continuing to turn-over your engine.
EXHAUST SYSTEM MAKEOVERS - First, it would be very helpful if Fluid Motion put out a warning about their minimally designed exhaust systems. They know the issue and they know that many of us have suffered through the unhappiness of not knowing upfront. Most of us have poured through manuals, videos, Tugnuts, and other forums studying our boats, but until you have a specific problem, you can't possibly catch every issue for these boats, and this is a big one everyone needs to know upfront. It would also be useful if Fluid Motion offered up some solutions from the factory or at least some DIYs before the issue arises. Osprey has a muffler drain valve that I'm currently considering.
That is all for now. Allen www.weavingwatersexpedition.com
Thanks Allen!
Very good summary of a batch of situations that can lead to an unbelievably bad outcome.
While I was familiar with all these situations, it’s a good reminder.
As to the 15 second start attempt limitation, on page 52 of the Yanmar 4BY2 Operations manual specifically covers almost everything you have mentioned with regards to starting.
https://www.yanmar.com/media/global/com ... M00011.pdf
They do not, however, recommend closing the seacock before another starting attempt. I would add that if your engine doesn’t start in 5-6 seconds you may want to turn on the emergency rotary switch to join the house bank to the starter bank.
Please let us know if you find a solution the exhaust flapper when being towed. I’ve thought of lifting the flap up and jamming a Rhino Sports ball into the 3.25” exhaust opening but not sure if that ball would stay tight.
https://sportsfacilitiesgroup.com/store ... -foam-ball
I agree with everything you have called out, and closing your seacock when towing is always a good idea.
However, I'm genuinely curious, would towing actually generate enough pressure for water to spin your water pump and potentially enter the engine/exhaust lift? It's a question that has been on my mind.
I have a fresh-water flush system on my system, and I've attached it and ran city/marina water into it with the seacock closed. The pressure from this is insufficient to spin the water pump and allow water to enter. 99% of the time, I leave the seacock open with flushing in case there is a drop in water pressure from the marina, but when I have had the engine off and the seacock closed to test what would happen if I made a mistake in the future, there just wasn't enough pressure. City pressure is anywhere between 35-80psi. I know that city pressure is enough pressure to push salt water back through my strainer and out the seacock, as each time I flush, I get a bunch of air bubbles off the port side until the strainer fills up and is pushed out through the seacock.
Water entering through the flapper or shaft cooling system seems more likely.
Excellent summary of cautions for each of us. They should be in every boat manual FM produces. In addition FM should produce a boat manual for each boat they manufacture. For my RT25SC they never produced a manual. With the compact design of our boats I believe we are more susceptible to these types of problems. I lost an engine during a tow with the seacock closed. The only explanation from the yard that did the repower was inadequate exhaust system design.
All good points. Much of this applies to built in on board generators too. You can't keep cranking if they don't start right away.
-martin610
My solution to the possibility of the muffler filling with water during situations as describe above was to install a drain hose and valve connected to the muffler side wall, near the bottom. The valve remains normally closed but I open the valve for situations such as towing or for prolonged start attempts. And yes, you have to remember to close the valve again!
This thread needs to be bookmarked by every Ranger/Cut owner. When all contributions are made, I will print out this thread and keep it on the boat with all documents to be passed on to new owners whenever I decide to sell. This is one of the “dirty little secrets” of our vessels.
Thread is very interesting to me! I have a 2016 C30-CB, and by the sounds of it, my exhaust hose is routed very differently than others. It goes in a "slanted uphill" direction from the flapper and around the back of the transom before making its way to the muffler, that would make it nearly impossible to have water make its way to the muffler, unless the boat was in VERY violent seas or the transom significantly low in the water. Is this not how others is designed?
Yes, my exhaust hose from the muffler slants up above the rudder mechanism as the space allows prior to the exhaust port on the side of the boat, however it is minimal. The other way the water lift muffler can fill up is with continued cranking the engine if it does not start. My Yanmar owners manual provides a warning about continued cranking the engine without first closing the sea strainer.
I'm dealing with a hydrolocked Westerbeke generator on a 2021 32 CB right now for the same reasons. Worked great after the survey when I bought it, now I'm facing thousands of $ in repair after running the generator once.
Fluid Motion, "Sorry, it's a 1 year warranty...."
If the raw water plumbing is installed correctly in the boat as per the manufactures installation manual. 90%+ of the hazards are eliminated. When the installation is marginal extra weight onboard, passengers gear, +full fuel and water can tip the scale and increase the hazard significantly. Many times the manufactures design is correct but the technician doing the install does not follow the design specifications. This is a quality control issue. There have been many threads about this in TugNuts, discussions at rendezvous and at the dock discussions. When the question is asked to a customer service representative at Fluid motion their answer is yes the install design follows the engine manufactures specification. They are correct about the design but in some cases not about the install. It's not a bad idea to check the install. Chances are right or wrong you will own the repair if the engine has water ingression. That is pricey!!!
I'm not sure this will work in your C30. When I read the Volvo installation manual I found the spec. 12" or >12" for the exhaust hose installation. In my C26 it was 10" or less when the boat was loaded. I found this when I was rewiring battery cables for better placement of batteries so the boat did not list to the port ( Moved house bank to starboard side) I noticed how low the exhaust hose was installed. Fortunately the technician that installed the hose left a lot of slack in the hose. Or possibly it was the correct amount but the technician installed the hose incorrectly. I was able to lift the hose enough to make a non- vented loop and increase the rise to 14" which is 2" above spec. I will show a photo of this. In the photo I removed the original cable tie and adjust it above the transom support. In the factory installation there was only one Cable tie holding the hose in place as shown in the photo. Once I positioned the exhaust hose in a elevated position I installed additional heavy duty cable ties and mounted them to the Transom support. This positioning provided a quick rise in the exhaust hose less than 4' from the hull exhaust outlet. The hose maintained this elevation then downward run to the exhaust can. The exhaust can has a anti slush nozzle on the bottom. This nozzle should be pointing toward the bow.
Hose mounted higher across transom. As you can see this is a marginal install using one cable ties to hold the hose. Not what you would expect from a quality boat builder. I used heavy duty ties and mounted three to support the hose.
gallery2.php?g2_itemId=51090&g2_imageViewsIndex=1
gallery2.php?g2_itemId=68972
When I was involved in this project I found another issue. The technician that installed the bonding wire to the rudder box installed it without enough wire restricting the movement of the rudder arm. This ripped the wire loose so there was no bonding protection the the rudder box and fasteners. I made up a longer bonding cable and repaired.
gallery2.php?g2_itemId=70574https://www.tugnuts.com/gallery2.php?g2_itemId=68972
gallery2.php?g2_itemId=70565
photo of the nozzle at the bottom of the exhaust can.
gallery2.php?g2_itemId=70780
Hello with an update. I installed the muffler drain - as done by others mentioned above. I installed this exhaust hose check valve. I have been in rough waters again and anchored at rough waters and heavy tide flow. No water back flow via exhaust now - my original issue. No water entering via seacock to water cooling system during those heavy tidal flows. Haven’t tested a tow yet and hope I don’t have to! Check valve is Centek 5” SKU 1200377.
