For those of us with the Merc/Cummins QSD 2.0 150 engine, I would like to answer my own question:
I believe most of these engines have the Sherwood raw water pump. After much research I have found the following information on our sea water pump impellers:
* Cummins QSD 2.0 150 EI water pump info
The impeller is Sherwood part # 10615 or Sherwood 10615A. 10615 K is a kit, includes gasket(s), not used, and O-ring.
approximately 1 5/8” wide and 2 5/8” diameter. Shaft is keyed. Hub is aluminum. Impeller number is cast in the
rubber right at the edge of the hub on the side, and should be legible on a used impeller. COST IS $30 to $40. Find on
Amazon, Pumps Direct, E Bay and other sites. There are some cheaper, but the source is questionable or used parts.
Mercruiser part # 47-879312025 is priced at $130.00 plus. It will probably will be the Sherwood impeller (see above}
in the box. The last one I bought from Mercruiser was this Sherwood impellor in a Mercruiser box
Based on my experience, I would change this every 200 hours. The one that was in the boat after purchase
was maybe 4 to 5 years old. May have been run dry. Found chunks out of the impeller blades (recovered from
the intercooler).
I just changed one of these with 146 hours on it and it showed minimal wear, some vane set, no cracks or missing
pieces. Ran it on the bench and it worked fine. It was NEVER run dry.
NOTE: I rotated it on the bench with the pump cover plate off to confirm that the vanes on the impeller will actually clock correctly if they are installed formed in the "wrong " direction, and they reset to the correct clock every time. Put a zip tie on the vanes and compress to get the impeller started on the shaft, then cut the zip tie and push impeller in to the pump housing. It will not go all the way in if the key comes out of the shaft. Also, if you put the pulley mounting hub (Forward end of shaft) in a vise and let the pump body rotate freely, you will not shock or strain the mechanical seal in the pump when loading the new impeller.
P.S. If you haven't cut the cabin sole back about 1 3/4" to gain clearance in front of the engine, do it first. What a great idea that I got off this site.
