Best way to winterize the freshwater system is run the tank dry. Once the tank is run dry the residual water left in the tank will do no harm to the tank if if freezes. Remove the water line off the water pump. (upstream side going to the tank) Use a spliced hose/water line fitting and attach to the water pump. Put the hose in a gallon container of RV anti-freeze. Drain the hot water tank by opening bottom valve.( you must either lift relief valve or remove water line going into tank to get it to drain properly) If you plan on doing yearly winterizing of your boat install a hot water tank by-pass valve or make up a by-pass hose and remove the cold in hot out water lines and connect together. Make sure all faucets are closed. Turn pump on and start with head faucet by opening. It may take a few moments for the pump to pick up prime. Once you have antifreeze flowing out of faucet cold side go to hot side. Shut faucet off pump should shut off. Check gallon container if needed replace with full container. Open galley repeat. If transom shower is installed repeat. Once completed but before re-installing water pump water line blow into the line and confirm no water is in the line going back to the water tank, blow residual in the tank, there will not be much so no worries about water in the tank. Install water line to pump, remove hot water by-pass, close tank drain. System is now winterized and ready for spring summarize. Take the antifreeze container and pour antifreeze down shower drain until the sump kicks on. Once pump shuts off, repeat until a good mixture of antifreeze is filled in sump pan. Pour what ever you have left from the two gallons of antifreeze down sink drains and deck drains.
