dpiano
- Jul 16, 2011
- C-288 C
- Spindrift
The furnace on our 29 ranger has conked out again. Sure marine in Seattle replaced the drive motor last march. They also replaced the hot and cold sensors and the evo control. Back then, the furnace would shut down and give an overheat code. However when I sent the furnace up to them they ran it for hours on the bench without overheating, before they did the repairs. After that it ran ok during the spring but then of course the furnace was not used through summer. Now the furnace is shutting down and giving an 08 code, which indicates a bad motor. Sure marine met us at shilshole last week, did a reset and furnace started. He is saying the heat duct was installed wrong by Ranger; it should not have a 90 degree bend coming out of the furnace causing it to run too hot. After the tech left, the furnace shut down again. I called Webasto and their tech said that the bend shouldn’t cause a problem. I remove the furnace again and sent it to Sure Marine. They started it on the bench and it ran fine all day. They are very helpful, going to replace the drive motor again, 2 days before the 6 month warranty expired on the second motor even though they are not sure why we are having trouble. Last march Sure was saying there was possibly a restriction in the hot duct. I pulled the fridge, crawled in and saw no kinks in the duct.
Anyone have any good ideas about this?
If we keep having problems I may want to rip out the webasto and put in something else. I read somewhere on this site somene replaced the webasto with a Planar. It’s made in Russia, but on the web it looks suspiciously like a webasto. This sure is discouraging!
