Webasto F01 error
dbsea
HALCYON
I’m getting an F01 error on my webasto, indicating flame not present. Just brought the boat to Everett and I’m down to about 20% fuel level. Was planning to refuel here after the haulout work. Is it possible I’m below the standpipe level for the webasto intake? Or perhaps the fuel filter needs to be changed?
I would first try to restart it about 3 times, if this does not work I would then change the fuel filter. When mine goes out it normally takes more then one time to get it going again.
BO-J
Thanks, I’ve tried 3 times unsuccessfully. I ordered a fuel filter which will be here Wednesday. I’ll also see if it behaves after refueling.
If I were a betting man I would say your fuel level is low and the pickup tube is not picking up diesel. My R-27 Webasto would lose prime if I was below 40 gallons with a 100 gallon tank.
Hello Dave B.
Sounds like your fuel level is low like mention below. Go ahead and get some fuel and you might also need to prime it several times sense you run out of fuel and lines will have some air already.
good luck!
