Almanac
- Oct 13, 2020
- R-21 EC
- Fool's Mate
I have a 2021 C-28, I don't believe my Webasto heater has ever worked properly. It heats just fine, but the problem is when I set the temperature it heats past the temperature.
Tonight, I tested it by setting the temperature to 65 F. I checked back later and it was 88 F as read on the Smartemp display. Last weekend I set the temperature very low, like 50 F and I did see it turn off. So it is capable.. but if I set the temperature at anything reasonably 60 F or higher, it seems it just heats the boat continuously.
I recently replaced the Smartemp 2.0 controller with Smartemp 3.0 controller hoping that it would fix the issue, but it still happens. Diagnostics didn't return any failure codes.
Does anyone have any troubleshooting tips or know what's going on?
Below is a picture from the new controller's bluetooth app. Please note that I had the same problem on the Smartemp 2.0 controller before I upgraded to the bluetooth model. I was hoping this would fix the problem.
