Vance1965
- May 12, 2020
- C-28
- Jellyfish
Does anyone have experience with a webasto heater throwing an error code of under/over voltage? I have a battery monitor(Victron-712) that's saying I have 12.5v at the house batteries but it will not fire off. Is it normal to have the voltage drop to 12.0v at start up ?
When I switch batteries to supply 12.7v it works fine . It seems odd the the small difference causes an error. I remember having lower batteries in the past and the heater worked .
Webasto's site suggested batteries failing, bad fuseholder or loose electrical connectors. I am going thru the wiring now to look for obvious faults. I wonder if the heater itself could have a bad component that would cause this issue?
Any ideas or suggestions would be greatly appreciated.
