Webasto heater
markzorad
R-23 (Sterndrive)
Greyhawk
Webasto heater won't start from remote switch.
Fuse good. Thermostat seems to be working.
Can't figure out where the heater is located in C30 sedan?
Any help appreciated
There are actually two fuses for the Webasto. Did you check both? Not sure where it is located on your boat. Also, if you have a few failed starts you need to reset the unit. This is cone by removing both fuses and reinserting after a minute is up. My experience has also been fuel level. On my R-27 if I went below 40 gallons the pickup would lose prime. Once you lose prime it can take as many as five attempted starts to get it going again.
That worked.
Found second fuse and reset.
Will be good to have some heat tonight after crappy rough water in the Straight of Juan de Fuca today.
Gale force tonight!
Thanks knotflying
